54 Rear E brake cable finish - NCRS Discussion Boards
  • Brett D.
    Infrequent User
    • November 1, 1995
    • 21
    Hi guys,
    I need to know the finish for the sheet metal brackets crimped around the rear emergency brake cables on a 54. I have found some areas with black paint. Part of me thinks this is part of the blackout process, the other part is unsure.
    Thanks In Advance
    Brett
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 54 Rear E brake cable finish
    Black high gloss paint and dont for get the cable seals to help keep water out.
    • Brett D.
      Infrequent User
      • November 1, 1995
      • 21
      Thanks Roy,
      I won't forget the seals.
      Brett
      • Roy B.
        • February 1, 1975
        • 7044
        Originally posted by Brett Driscoll (26846)
        Thanks Roy,
        Brett
        And just as a little reminder also connect the other ends , then when you pull the handle the Corvette will hold on a hill.
        • Karl L.
          • February 1, 1977
          • 174
          Roy,
          Does anybody have these seals availible for sale?
          Karl.
          Can they be made from something? (would have to have pattern)
          • Roy B.
            • February 1, 1975
            • 7044
            Maybe some Chevy club sells them (47 to 54) but yes they can be easy to make like from carpet jute pad. Use the cover as a pattern
            • Karl L.
              • February 1, 1977
              • 174
              Thank You Roy.
              Karl.
