Vacuum Advance Can
Re: Vacuum Advance Can
Replaced vacuum advance can with the VC-1765 which is B26 on the can.A VC-1765 will either be a B20 or a B26. The latter was formerly VC-1808, but it's essentially the same specs at B20, so both were consolidated under the VC-1765 part number, and either is okay.
As previously advised, I suggest you check before leaving the store that maximum advance is achieved at about 12". Then you can check on the car to be sure that it yields about 16 degrees at idle.
The car has great driveabilty now and no ping at all on 93 grade fuel. The max advance is @ 12" and is 16 degrees at idle. Thanks to all...Bill- Top
Detonation when accelarating from a cruising speed then it would stop when the vacuum advance retarded it to mechanical advance with the 436 VAC. The idle is pretty much the same. It idles very well at 750 RPM and will idle down to 600 RPM without stalling...Thanks Again, Bill- Top
