Drain plug leak - NCRS Discussion Boards
Drain plug leak
  • Tom S.
    • March 1, 2004
    • 1087
    Drain plug leak
    I changed oil yesterday in my 65.I noticed the plug was not original, it was a self tapping typewith a fiber washer that was very brittle. I should have gotten a new washer for it then but did not. This morning I noticed a small puddle of oil under it. It was directly under the drain plug.I tightened the plug a little more hoping to stop the leak. It slowed a little but still leaks. What type of washer should I get to stop this? It is the only leak I have. Tom
  • James W.
    • December 1, 1990
    • 2640
    Re: Drain plug leak
    Well I'll put money on that it will not stop leaking no matter what you do since the leak is most likely coming from around the self-tapping plug threads. I doubt a nylon washer will stop the leak. I have this same situation on my '64 and nothing I have done has cured the leak.
    I had to buy a oil drain plug rapair kit from GM and must make this repair befotre the car goes back through flight judging.
    Best Regards,
    James West
    • Tom S.
      • March 1, 2004
      • 1087
      Re: Drain plug leak
      James
      Thanks for the input. Not really what I wanted to hear but I do want to get this leak stopped. All the cars and trucks I have had in my life time I have never had this problem.It is a new one on me. Tom
      • Bill I.
        • January 29, 2008
        • 554
        Re: Drain plug leak
        Tom, chances are that fiber washer has been used one too many times, Try a new one. Bill
        • Chuck S.
          • June 30, 1991
          • 184
          Re: Drain plug leak
          I had the same problem on my 1965 small block engine. It is all original with 61,000 miles. I`m the first owner so I know that Bubba never performed an oil change thus the plug was not overtightened nor cross threaded.
          I ended up installing a two piece self tapping plug with a built in drain plug. No leaks but it takes a few minutes to drain the crankcase.
          • Tom S.
            • March 1, 2004
            • 1087
            Re: Drain plug leak
            Bill
            I am going to try a new washer. I am going over to NAPA Monday anyway so I hope they have them. My garage floor has been taking a beating since I bought this one. If I get this leak cured I will be good for awhile I hope. I am really surprised I don't have more leaks, this car sat in a mans garage for 7 years. 65 k original miles. Thanks Tom
            • Dick W.
              • 10483
              Re: Drain plug leak
              Tom, use a thread sealant, such as Loctite Pipe Sealant w/Tefelon (PST). It will take care of a lot of leaks. I use it everytime I change oil. Just another insurance against leaks.
              Dick Whittington
              • Tom S.
                • March 1, 2004
                • 1087
                Re: Drain plug leak
                I thought I would mention I went to NAPA to get a few things and I asked the parts guy for a waher for my drain plug. He comes out with a metal washer with a rubber center inset. I put that on with some thread sealant and SHAZAM!!! No more leaky. Thanks to all. And anyone with a leak might want to try this if your threads are good. Tom
                  Re: Drain plug leak
                  Tom------
                  You mean like this? This is a GM #14090908 which was the drain plug gasket used for 1988-96 Corvettes and also the SERVICE gasket for all 53-87 Corvettes since about 1988. It works pretty well. It will stop your drips onto the ground. However, it will likely not completely stop the "oil film" seepage surrounding the drain plug.
                  The only thing that will completely stop all seepage that I have found is the torque-limited plug with elastomer seal used on later GM applications. Unfortunately, this is METRIC and is not easily retrofitable to your application.
                  • Tom S.
                    • March 1, 2004
                    • 1087
                    Re: Drain plug leak
                    Just like that Joe! Ihave had it in a few days and no leaks. Thanks for all the help. Tom
                    • Dick W.
                      • 10483
                      Re: Drain plug leak
                      Tom------
                      The Loctite PST will stop the seepage
                      Dick Whittington
