1963 Speedometer problem - NCRS Discussion Boards
  • Jack U.
    • November 1, 2003
    • 212
    I start the car up every 2 weeks and pull it in an out of the garage during the winter because it is a fuelie.
    The last 3 times I noticed that the speedometer needle jumps up and down from 0 to 30 mph when I pull forward back in to the garage. The needle sticks somewhere in the middle when I shut the engine off. When I back up the car out of the garage two weeks later the needle drops back to 0 mph.
    Could this be a problem with the cable?
  • Dick W.
    • 10483
    Re: 1963 Speedometer problem
    Originally posted by John DeGregory (2855)
    Jack, What kind of lubricant are you using on the tach cable? Hopefully it's just a cable. If not then it may well me the tach itself.
    Highly unlikely it's anything with the FI distributor. Now if you had a carb distributor that would be a different issue.
    By the way my 63 the LWC is your twin. White/red. JD
    ChePhart, he is talking about his speedometer.
    Dick Whittington
    • John D.
      • December 1, 1979
      • 5507
      OOPs. Well he will know what to do when the tach craps out DW. Sorry.
