This is a follow up to my slight vibration/missing problem.
I did some checking using my heat gun and found #8 cylinder over 130 degrees less than all others. I pulled the plug wire which had no effect on the idle. I checked for spark at the cap and replaced the wire with no change. I also put a spare plug on the wire to make sure I had fire on the plug. I did a compression check and found it good so I pulled the valve cover and checked the valve adjustment. Perfect. So if I have compression, apparent spark, what else could be wrong?
I know I have to have fuel so I noticed the vaccum for the brakes seems to come off the manifold on that cylinder. I don't seem to have a leak and don't know that would cause this anyway.
Although I am seeing spark, could the distributor cap be a problem? It's new. At higher rpms I can't even tell there is a problem.
