Upon removing my old tie rods and counting rotations ,in an attempt to keep it close to how it was when removed , they seemed to be all over the board ! One side had as little as 22 and 26 turns, while the other side had 32 and 28 turns . Seemed like a lot of Bubbaizing went on .
So now my new question is this ; Given a total restoration is starting from scratch , Shouldn't I just do the same with the tie rods ? By that I mean screw each tie rod end in as far as it will go , attach them to the Chassis, and work outward as needed ?
The Chassis Service Manual only states that if replacing tie rod ends "make sure each end is inserted at the same length into the rod." It does not say anything about how far. So is ther any problem with doing it as discussed above ? Ie. all the way in on both ends and equidistant on both ends with no staggering of the ends?
How did they do it originally at he Assembly line ?
Thanks for your time ,
JIm
JIm
