1957 aluminum intake manifold bolt torque - NCRS Discussion Boards
  • Art B.
    • 333
    Can anyone tell me the correct torque on the 2x4 aluminum intake manifold bolts? I cannot find it anywhere in the ST-12 manual. The 1957 Chev passenger car manual only states 25-35 ft. lbs. for the cast iron intake manifold bolts.
  • Steven B.
    • June 30, 1982
    • 3976
    Re: 1957 aluminum intake manifold bolt torque
    Art, from 11/13 & 14/09 posts:
    Hello,
    My books are conflicting on torque specs for the 2x4 aluminum intake manifold, which shows 20-25 lbs. Seems kind of too much for an aluminum manifold to me, is the sequence to tighten the bolts the same as the cast iron one? Any information appreciated...thanks.
    November 14th, 2009, 07:23 AM
    Terry Deusterman (11486)
    Re: 61 aluminum 2x4 intake manifold.
    David
    20-25 is correct and no difference in procedure then cast iron manifold.
    • Art B.
      • 333
      Thanks. My reason for asking is that I have a small antifreeze deposit at the manifold at the front right corner. It occurs after a drive. It is right where the temp sender is located, but it is not coming from that. Hard to get a torque wrench on those two front right bolts.
      • Steven B.
        • June 30, 1982
        • 3976
        Art, there are other comments answering that post about wrenches, the end bolts, etc. I use an open end on my 653 manifold, go through the sequence and I am most careful of the end bolts as those ears are most likely to fracture.
        Steve
