Finished installing new trailing arms, new u-joints, new bushings in strut rods and then went to get the rear end aligned. I had installed shims (original style) approximating what was in it with the old t-arms.
I took my car down to an alignment shop that was recommeded by corvette restorer. When the alignment was done, I thought it strange that on the RH side they didn't use any shims on the inboard side to get the toe correct. All the the shims went on the outboard side. Does that sound normal? The LH side had shims both inboard and outboard as before.
BTW - I watched the process and they used original style shims that I provided, took the bolt out, took their time (over two hours) to get it right and obviously used a computer to get the numbers. They gave me the print out of before and after numbers but don't have them in front of me at this time.
Drove it home with no issues. Thoughts on the shims?
