Wheel well cleaning tips! - NCRS Discussion Boards
  • Tom S.
    • March 1, 2004
    • 1087
    Does anyone have a tip on cleaning the wheel well's on my 65? I have the frame all clean in the rear area, down to bare metal. What works good on the wheel well's? Ther is quite a bit of dirt and what seem's like to much undercoating. Thanks for any help. Tom Stanton #41491
  • Tom S.
    • March 1, 2004
    • 1087
    Re: Wheel well cleaning tips!
    I got the right rear where it looks like new. I wire brushed the heck out of it. Took some big globs of old undercoating off, got the frame down to bare metal in that area and painted it in smie-gloss paint. It looks better than new. Any ideas will be appreciated, I have the rest of the frame and crossmembers and 3 more wheel wells to go.Thanks Tom
    • Alan D.
      • January 1, 2005
      • 2027
      Well since no help yet I'll throw in my 2 cents.
      If you desire to remove all undercoating use Brake Cleaner Spray, about $2/car at Wally World. Make sure its done in a well ventilated area.
      However if you think it has not been touched and would like to get it back to original try some cleaner like Simple Green or I used G-5 Degreaser by Ultra One. These will not remove any of the primer, paint, or undercoat. It takes some time but great result.
        • 6940
        Tom, mineral spirits will also work ,not quite as harsh as brake cleaner,
        • Tom S.
          • March 1, 2004
          • 1087
          I think the rear wheel wells are original. I knocked some bigger chunks of old undercoating off. I will fix those spots with new undercoating and paint the whole area with semi-gloss as new. The car is just dirtry, but in very good shape otherwise! Thanks for the in-put Tom
          • Randy R.
            • March 1, 1983
            • 477
            Be careful. Many total restorations started with just a good cleaning.
            Randy
            • Alan D.
              • January 1, 2005
              • 2027
              Yes Randy is right, right, right.
              I would do the cleaning process since its only original once. You will find that the undercoating did not cover entire area nor did any paint.
              See "1964 wheel well undercoating" April 23, 2009 (don't know how to copy in link form, sorry)
              • Mike M.
                Director Region V
                • August 31, 1994
                • 1464
                Tom,
                The final coating inside the wheel wells was performed via the Black-out process.
                Flat black, not Semi-Gloss.
                HaND
                • Joel F.
                  • April 30, 2004
                  • 659
                  Hi Michael,
                  At this point the under coating would already have been applied so the black out would be over the under coating, correct?
                  • Mike M.
                    Director Region V
                    • August 31, 1994
                    • 1464
                    Hi Joel, good to hear from you.
                    Correct, the undercoating was applied right after the body assembly was completed.
                    The final coverage sequence was: undercoating, primer, body color paint, blackout.
                    HaND
                    • Mike M.
                      Director Region V
                      • August 31, 1994
                      • 1464
                      I should mention that the primer and body color were not full coverage, just overspray from the top coats.
                      HaND
                      • Tom S.
                        • March 1, 2004
                        • 1087
                        So the blackout in the fender well's should be flat black? Where is flat black for blackout mentioned? The blackout underhood is mentioned as being semi-gloss black. I thought all the blackout paint would be the same? I have only done 1 fender well, and I did it in Semi-gloss. I can change if need be. Thanks for the help. Tom
                          Tom -
                          The blackout paint used underhood and in the wheel wells was the same paint; it was flat to semi-flat, definitely not semi-gloss.
                          • Tom S.
                            • March 1, 2004
                            • 1087
                            John
                            I have been trying to follow my tech and judging guide for info. On page #134 it says that the firewall, inner fender skirts, dust shields and splash shieldsall have a black semi-gloss finish. So now I am really confused. What paint is the blackout paint rally??I have been using a semi-gloss rust -oleum paint because this is what is in the manual. Please advise! Tom
                            • Mike M.
                              Director Region V
                              • August 31, 1994
                              • 1464
                              Tom,
                              As John pointed out, the blackout paint was Flat Black with some variation in texture.
                              Certainly not Semi-Gloss.
                              In the past seven years since the printing of the latest Fifth Edition there has been sufficient research performed, contributions of information of original cars gathered and input from the GM people who were there, to establish a consensus of the Blackout finish.
                              Thank you, Tom, for bringing attention to that passage in the Fifth Edition of the JG, it will be addressed and updated in the next revision.
                              HaND
