air filter for a single carb C-1 (1959) - NCRS Discussion Boards
  • Charles K.
    • May 31, 1989
    • 22
    Anyine know where I can get a reasonably priced, replacement filter for my 240 HP. C-1
    Re: air filter for a single carb C-1 (1959)
    Charles -
    Paragon has a couple of reproduction 1x4 air cleaner assemblies for around $200.00; doubt if you'll find anything less expensive that looks reasonably correct.
    • Charles K.
      • May 31, 1989
      • 22
      Thank you for the quick response. What I'm looking for is the air filter cartridge. CC has one for $54 but that seems really steep. There has got to be replacement air filter cartridges out there that fit the height requirement.
      • John F.
        • March 23, 2008
        • 2395
        Charles, My 62 base motor 1x4 aircleaner I bought at O'Rielly's. I believe it is WIX#542100 Made In USA. Hope this helps. It is 13.75" outside diameter and about 1.5" high.
        John F
        • Bruce B.
          • May 31, 1996
          • 2930
          Charles,
          AC Delco part number AC350C fits my 62 Corvette 340 HP air cleaner.
          It is about 1 1/2 inches thick and about 13 3/4 inches in diameter.
          Check your email.
          Bruce B
          • Charles K.
            • May 31, 1989
            • 22
            Bruce, Thanks for the info!
