Spare tire tube question - NCRS Discussion Boards
  • Rod M.
    • July 30, 2008
    • 36
    Does anyone know if a Firestone 205/75/15 from Diamond back tire fit in the spare tire tub of a 1966??
  • Rob M.
    • April 30, 2003
    • 657
    Re: Spare tire tube question
    Yes.
    That's the exact tire that I have on my car and in the tub. I had to use the longer bolts (like for knock offs) to make it easier to raise the tire up into the tub, but it fits. I am not sure why getting the tire up in the tub with the standard bolts is an issue, but it is.
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
    • Rod M.
      • July 30, 2008
      • 36
      Rob,
      Thanks for the response. My car came with 215/70/15 and they handled such fine. I assume that the 205/75/15 will also handle fine. I am going to order a set today. A friend with a 65 is also going to order a set.
      Thanks again Rod
      • Ronald L.
        • October 18, 2009
        • 3248
        If you have the original set up a P205 will fit, less the air, once inflated you will not be able to close the cover.
        • Rod M.
          • July 30, 2008
          • 36
          Ronald,
          Thanks for the reply. I do not have the orginal tires however I do need new ones. I was hoping that the 205/75/15 would fit in the tub. Do you know if 215/70/15 will fit? The car came with KO wheels.
          Rod
          • Rob M.
            • April 30, 2003
            • 657
            Ronald,
            Rod
            Rod,
            If you car is set up already with the longer bolts used with KO wheels that hold the support tray for the spare tire, you should be fine with the 205's (even with air in them). You will be able to raise it up into the tub.
            IF you have the stadard bolts, you will not be able to get the spare raised into the tub.
            FWIW, I am happy with the Diamondback tires that you are considering. Plus, I have a spare that I can really drive on if needed.
            Rob
            '08 6 speed coupe
            • Rod M.
              • July 30, 2008
              • 36
              Rob, Thanks. I believe that these tires are the closest thing to orginal for my car so I have ordered a set.
              • Ronald L.
                • October 18, 2009
                • 3248
                Rob,
                Which diamond backs did you get/ do they have an accurate white wall for 66?
                  Originally posted by Ronald Lovelace (50931)
                  Rob,
                  Ron -
                  Diamond Back applies (vulcanizes) the white (or red, or blue, or gold, or whatever you want) to the tire, and trims it to whatever width and distance from the rim you want; every set is a custom job.
                  I have a set of their 205/75-15 (Firestone) redline radials on bolt-ons on my '67, and the spare fits in my tub, with about a 3/4" gap at the rear of the tray (with the "long" front hanger bolts and rear lock bolt). However, my tub is a reproduction, and they're slightly larger in diameter than the original tubs were.
                  • Rob M.
                    • April 30, 2003
                    • 657
                    Rob,
                    Ron,
                    I bought the same Firestone tires that John describes. I ordered mine with the correct white wall configuration for a 66 for judging purposes.
                    Rob
                    '08 6 speed coupe
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      Thanks Guys (John & Rob), From their website and John I knew they had the 67 configuration but their chart did not show the 66 wsw configuration. P205 as we know a P215 is going to hit in certain circumstances...
