C2 (C1, C3?) tire valve caps -- Dill markings
Re: C2 (C1, C3?) tire valve caps -- Dill markings
Mike - I read your Posting as the DILL Valve Cap as one of the ones Wayne posted a picture of is the only acceptable Valve Cap for NCRS Judging. Do you have some information to share that supports that? Thanks, Pete- Top
Hi Peter,
Apparently some confusion.
My comment was in response to Waynes question "What do Judges EXPECT to see".
The "only" was referencing the two embosses limited to the "Dill" and the "627", meaning not to include the embossing at the 3:00 position which has not been observed on TFP Mid-Year caps.
Would some Judges deduct for this added marking? Since they are probably just looking for the "Dill" and the "627" per the JG, perhaps not.
HaND- Top
} and let the bidding begin.
One of you tricksters should try this. Often I see topics discussed on this board that immediately result in some item being posted on eBay with authoritative description.- Top
Mike - Greetings from the Land of Enchantment. Thanks for the clarification. Since I have seen the Schrader valve caps on several original mid-year spare tires (I have one) and I have no reason to believe these are not original, I didn't want to get deducted because mine didn't have a DILL 627. We'rePete
- Top
Schrader cap; is a photo possible?
Any chance you could post a nice close-up image of your mid-year Schrader cap? I'd like to add such a photo to my new judging guide so that I can give full credit when judging if I see the correct non-Dill cap.
Gary- Top
Re: C2 (C1, C3?) tire valve caps -- Schrader valve cap
This is the "real deal."
Schrader valve cap on 67 Bolt-on wheel valve stem.Attached Files- Top
The '67 judging manual just says the valve stem cap is hard black plastic. Does it matter for points if it is a Dill or a Schrader?Big Tanks In the High Mountains of New Mexico- Top
