Judging manual states wire clips were installed on inner fenders and firewall before blackout, therefore, rivets would be painted. Were the rest of the brackets and plates installed before or after blackout i.e. windshield washer reservoir mounting bracket; horn relay mounting bracket; hood hinge support brackets; voltage regulator mounting bracket; radiator overflow tank mounting bracket? If these were installed after blackout the rivets would be unpainted. Is this correct?
Brian
Brian
