Door Striker 58 - NCRS Discussion Boards
Door Striker 58
  • Brad H.
    • August 12, 2007
    • 724
    Door Striker 58
    Was taking the striker off to adjust shims and the screw plate from behind fell off down into nowhere land, how do you access this area to retrieve it/ Thanks again, Brad.
    Re: Door Striker 58
    Try a magnetic 'fish' tool...
    • Brad H.
      • August 12, 2007
      • 724
      Re: Door Striker 58
      I found the screw plate sitting above the frame in a hand size opening, I now have it in my hand, don't want it there, does it have to go back up in the same place, were these riveted in place when they did all the panel work or is there an access to put it back in place? Thanks again, Brad.
      • Roger W.
        • January 29, 2008
        • 564
        Re: Door Striker 58
        I don't think that the holder can be rivited back into place. I would concentrate on getting the screw plate back into place. Unless you have some kind of damage in your fiberglass that allows you to get your hand into that area, the only way I see is to take the gas tank cover off. I can't get my big meathook in there on my 59, but a smaller hand may be able to. I would have to attach some kind of handle onto the plate and try to get it up there. Then hold the screw plate with a bolt without a head through one of the holes that the striker plate mounting bolts goe through. Mount the striker plate with the other two bolts. Remove the headless bolt and replace with mounting bolt.
        Just remember that you can't take all of the bolts out or the plate will fall again.
        • David L.
          • December 1, 1981
          • 116
          Re: Door Striker 58
          I posted a similar reply to Roger's back a while. It should be in the archives.
          David Lyon
          • Brad H.
            • August 12, 2007
            • 724
            Re: Door Striker 58
            Hooked screw plate to extendable magnetic rod pushed it up to location needed, had helper run philips driver thru hole of plate and got it hooked up, all from hole above frame nder door post area. Thanks all again. Brad.
