Hood Catch Plating - NCRS Discussion Boards
Hood Catch Plating
  • Peter J.
    • September 30, 1994
    • 586
    Hood Catch Plating
    Is the screw that the hood stop/bumper is mounted to plated or unplated? Did you guys remove it or leave it attached when you sent it to be replated.
    Thanks, Pete
  • Donald T.
    • September 30, 2002
    • 1319
    Re: Hood Catch Plating
    It is plated. I remove the screw for media blasting and cleaning prior to plating. I then plate them separately for corrosion protection. Otherwise the threaded portion of the screw in contact with the nut will be unprotected.
    Don
