I had a noise which I and a coulpe others felt a had a set of gears and / or pinion bearings that were bad. From 50 MPH on up, I had a growl as well as a vibration that I could make change with acceleration, coast, deceleration, etc. So yesterday, I pulled the diff out to send it to the rebuilder. While pulling this apart, I noticed I have a tight half shaft joint. Have any of you experienced a joint to cause the symptoms described? I have not pulled the cover off of the diff yet but I must say, laying on the bench, I cannot find anything with the diff that alarmed me. By the way, this is a car I just purchased so I have no credible history. The previous owner says he never had any noise.
Tim
Tim
