What can be checked /adjusted to correct poor starter gear / flywheel engagement on a 66 - 327. Engagement is positive at times and then again somtimes just a grinding sound is heard without the starter spinning the engine. (I'm pretty sure this is not the original starter for the engine, its a automatic trans.).
People I talk to have little confidence in shims so I have not tried this approach and this does not sound like a problem that a shim can fix.
I have changed out the starter once and the same problem exists. I believe voltage to the solenoid is ok, I have ordered new starter bolts (just in case), teeth appear ok on starter and flywheel. I suppose the fly wheel could be bent or cracked but it looks good from what I can see by removal of the flywheel pan.
Is there anything special about the 327 starter, cast iron nose, etc. that only the original starter should be used? Any trouble shootoing suggestions are appreciated. Thanks much.
