Some facts and a measurement...
I reconfimed my casting numbers just to be doubly sure... 3rd Arm Bracket is 3742688, which is the later version with the thicker bosses, and the Idler Arm is 3731801. So I seem to be good there.
Shims: I confirmed that the shims are in place between the suspension unit and the frame. HOWEVER, the thicker edge (approx 1/4") is towards the FRONT of the car. Is that correct, and could that make that much of a difference in the clearance?
I also measured the "rise" of the Idler Arm, hopefully to determine if it's bent. In the attached picture you'll see that I placed a steel rule at the flat/bottom of the Arm and then attempted to measure the rise/height of the arm. It's approx 5 1/8 inches. (I'm sure you'll get a chuckle at my attempted effort to indicate the measurement in the picture)
Whew... good thing this isn't my paying day job. I'd starve.
