Need help with wireing on early 68. New wiring for dash. Center gage wireing in question. Have brown wire with single plug, where does it go ? Have black wire with ring terminal, assume it is ground, where does it go ? Is their a wire that goes on post of seat belt warning circuit board ? Thanks, trying to make Gettysburg.
68 wireing help
Re: 68 wireing help
Alan, the brown wire is it long enough to go on the e/brake switch and there is ground on the center console piece around the ash tray area, and take a look at the gage cluster I believe theres one there, the eyelet not maybe correct, there both spad connects as I recall.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Re: 68 wireing help
Alan, the brown wire is it long enough to go on the e/brake switch and there is ground on the center console piece around the ash tray area, and take a look at the gage cluster I believe theres one there, the eyelet not maybe correct, there both spad connects as I recall.- Top
Re: 68 wireing help
Alan, looking at the wiring diagram, the is a brown wire on the ing. switch is there a spad connector there? Thats not to far from the console.
Alan send me your e/mail and I will send you a diagram I found on internet.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
