65 fuel tank date? - NCRS Discussion Boards
65 fuel tank date?
  • Tom S.
    • March 1, 2004
    • 1087
    65 fuel tank date?
    Is the date in the circle with the big A in the middle? If so I have O on one side I on the other of the big A. Then below the A is co. The manual says the date should be on the outside edge on a flat spot and stamped. If this is correct I need help? Thanks Tom
    • April 1, 2000
    • 477
    Re: 65 fuel tank date?
    What you are seeing is the manufacturer's logo, i.e. O.L. Anderson. I'm sure somebody will chime in with info on the date stamp.
    • Tom S.
      • March 1, 2004
      • 1087
      That is exactly it. I have the trank about 80% clean except for some undercoating or blackout . I don't see anything as of now. I don't want to disturb the tank too much in fear of staring another problems. I have no leaks right now and would like to keep it that way.I am sure it is original but would like to find the numbers. Tom
      • Tom S.
        • March 1, 2004
        • 1087
        Any help on location of the date? Tom
        • Tom S.
          • March 1, 2004
          • 1087
          Can anyone help with locating the date stamp on the tank? Tom
          • Wayne M.
            • March 1, 1980
            • 6414
            Originally posted by Tom Stanton (41491)
            .....The manual says the date should be on the outside edge on a flat spot and stamped. If this is correct I need help? Thanks Tom
            Tom -- I can't see any reference to a date in the '65 TIM&JG, 5th ed., page 159 (top). Can you give us more info on where and in what manual ?
              I have seen some original tanks dated via paint and stencil, but that appears to be a hit & miss issue. Sort of like a pallet of tanks was stenciled with only a few bearing the stencil...
              • Paul J.
                • September 9, 2008
                • 2091
                Tom, there was a picture of what Jack's referring to that was posted here some time back. I thought I had a copy but I can't find it. It's in the archives somewhere.
                Paul
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  Jack -- I copied that 1964 photo that Joe T. (?) posted, showing the rows of tanks on a pallet. Seemed to be stencilled with "ST LOUIS" (first line), and a part number (?) on the second. This particular photo showed every tank so marked, but I agree that a very small percentage of the tanks of other years had such markings.
                  • Jim S.
                    • March 1, 1986
                    • 1392
                    Tom,
                    I am not sure There is a date, but here is a link to check out about the stencils
                    There are others as well .
                    Do an advanced search in the Technical Discussion under "gas tank Stencil"..
                    JIm
                    • Jim S.
                      • March 1, 1986
                      • 1392
                      Wayne ,
                      You mean this one ?
                      • Tom S.
                        • March 1, 2004
                        • 1087
                        I think I have to apologize. I had my shop helper reading the manual while I was under that part of the car. I think what she thought was where she read a notch stamped into the lower outer edge of the fuel tank on page #159. Then below that she saw the serial#'s and the months think that should be stamped into the tank. Sorry for the confusion. Tom Stanton
                        • Wayne M.
                          • March 1, 1980
                          • 6414
                          Originally posted by Jim Schwering (9598)
                          Wayne ,
                          You mean this one ?
                          Jim -- yes; did you notice that the stencil is on the bottom half of the tanks (corner tab bends down toward ground), and that characters are upside down when tank installed.
                          When I removed the tank from my late '65, I took special care when cleaning off the gunk, ready to record any stencil. I found nothing.
                          • Jim S.
                            • March 1, 1986
                            • 1392
                            The 66 I am restoring had nothing on it either. I guess from 64 -to 66 a lot of the stencil practice had changed.
                            I can't figure out why they stenciled any of them, as they were only for a corvette, and went into all of them , (except for 36 gals). One stencil on the pallet would have sufficed. And in fact probably did after 64.
                            JIm
