Best Glue - NCRS Discussion Boards
Best Glue
  • Glenn B.
    • June 4, 2008
    • 76
    Best Glue
    I'm ready to put the engine suffix tag on my 73; any ideas what product works best for this application? Thanks to ALL!
    Glenn
    • 6940
    Re: Best Glue
    Glen, I used the 3m spray tack adhesive, the problem is, a can of this isn't cheap, but if you know a autobody or auto repair shop they may help you out.
      • 11608
      Re: Best Glue
      I use Avery label paper and hope for the best. It's already got adhesive on it, and then I usually recommend getting the valve cover as clean as possible before applying.
      Actually there is a newer product that is supposed to be "resistant" and better for "outside" environments that I've tried once or twice. No feedback yet.
      The 3m adhesive "may" result in a soggy label depending on what you used to make it.
      Patrick
        • 6940
        Re: Best Glue
        Patrick,I promise I didn't get your label soggy.
          • 11608
          Re: Best Glue
          Oh, I know that mine will tolerate it.
          Not knowing what Glenn used, if it's just regular paper then it'll be a mess.
