Have to turn starter for several seconds to start hot, sometimes get a missfire before starting. Excellent mechanical condition L79, all stock except for Pertronix I ignition(all voltages check out) and a Mr. Gasket heat shield between carb(new correct Holley with no flooding on throttle plates)and manifold. 15 in. vacuum at idle.Has power brakes and factory AC.Haven't checked for vacuum leak at brake booster but brakes work. Mechanic says fuel evaporating as soon as it hits inside of hot intake and should give a little pump before hitting start. Could throttle plates be too far open and not pulling enough vacuum at start to pull fuel through idle ports?Vacuum leak or other problem? Car runs fine after starting.
Thanks in advance
William Ford
Thanks in advance
William Ford
and I had to crank just a little more than usual to start the engine after heat soak.
