Window Adjustment - NCRS Discussion Boards
Window Adjustment
  • John C.
    • September 30, 2001
    • 130
    Window Adjustment
    Can someone help me understand how to adjust a door window, it needs to go back so it fits better with the top. Thanks
  • Mike E.
    • February 28, 1975
    • 5134
    Re: Window Adjustment
    If by "go back" you mean it needs to go aft, or toward the rear of the car, there's really little provision for doing that. GM indicates that if you have a hardtop, you adjust the windows to the top, and then adjust the soft top to the windows. The ST-12 manual, as I recall, shows how to do some window adjustment. There are stops at the top of the door that can be adjusted if the front or rear is to high or low, and the screws along the edge of the door by the latch (the large ones with integral star washers) can be used to adjust them in or out.
