Corvette horns
Re: Corvette horns
After looking at Jack's pic., I noticed my 72' terminal is at a different location, the mounting bracket is not rivited but has a large nut that can be loosened to relocate position or removed bracket and the housing is designed different. Maybe a service replacement causing the difference or at lease two different designs for 72' ?? SteveTerry- Top
Re: Corvette horns
The large nut is generally regarded as an indicator of a service replacement horn. The replacement horns usually are provided as a kit with several mounting brackets. One choses the proper mounting bracket and orients the horn as necessary, and bolts them together. Thus one kit can fit many applications.
I'm not where I can examine the horn tonight but I believe the horn mounting arm is factory fixed, not a kit. The part number 9000 last 0 is over-stamped with 032. The date appears to be 1G3. I will reply to this tomorrow after I take a closer look at it and post a photo of it.- Top
Re: Corvette horns
Scott,
The horn on you '72 is the correct one. The '72 horn is larger than the '70-'71 horn, and a much wimpier sound. My original horn sounds more like the horn off a model A than off a "modern" car. Kind of a boop, boop sound instead of a loud "honk". Physically, the horns "look" the same, but the '72 is smaller.Kurt Geis
Chairman, Midway USA Chapter
Targa Blue 1972, Top Flight and Duntov Award, 2014
Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
Arctic White 2013 60th Anniv Special Edition Conv.- Top
Re: Corvette horns
My 1970 with the two horns sounds great. I can't imagine why GM would want to go with one horn in 1972 that, according to some here, sounds that weak.
I paid less than $20 including shipping for the horn off of eBay. The seller had it listed incorrectly as an 072. The seller posted a correction after I questioned it being an 072 Corvette horn for a 1972. It was still painted over so it was hard to tell even from the close-up photos. After I received it I used lacquer thinner to be able to see the numbers and date of 1G3.- Top
