I had my original master cylinder cap replated for my 67 a couple of years ago but I am still not happy with the color. I want it to look like this. Where can I get my cap replated to look like the one pictured. Thanks in advance.
Master cylinder cap replating
Re: Master cylinder cap replating
It won't look like the picture but if you're interested in correct plating, call Steve Gregori 559 875-0290, excellent plating work and fast turn around time. He's an NCRS member.Jack Corso
1972 Elkhart Green LT-1 Coupe 43,200 miles
Top Flight 1994, 2018 & 2021- Top
I had Steve replate mine in 08. While at Bloomington last year a judge commented that the cap was not gold enough. I did not receive a deduct but want to get it right if he was correct. Here is a pic of mine, should I just leave it alone?Attached Files- Top
Good point, it does look a little too silvery. Richard Fortier (DriveLine) also does plating. I had one cap done by each and I was satisfied with the gold content of both.Jack Corso
Steve Gregorio did my cap a few yrs ago. It turned "silvery" over time so I sent it back and he redid it under warranty. No problem since.- Top
Master cylinder cap replating, here's how it is done
Plating:
Afterplating:
Then after a little post plate shining, the dichromate dip:
Then while drying, hit it with a hair dryer if you want to bring out some reds and greens:
Having fun,Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
- Top
