Tie rod ball joint nut sizes - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    The threads on these joints on both end of the tie rod are 7/16-20. However, the nuts on the relay rod take a 11/16 wrench while the steering arm end take 5/8 wrench.
    Other than maybe for a quick way of identifying which end is which, what is the reason for the difference in wrench sizes?
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
  • Rich P.
    • January 12, 2009
    • 1361
    Re: Tie rod ball joint nut sizes
    5/8" came from the factory 11/16" was replacement.
    Rich
    • Steve L.
      • June 30, 2001
      • 763
      Rich,
      Are you sure about this. I don't remember replacing any of these components.
      I wouldn't have replaced these unless the steering was loose. I'm sure I would have remembered if the steering was loose.
      Steve L
      73 coupe since new
      Ottawa, Canada
      • Rich P.
        • January 12, 2009
        • 1361
        I know for sure that is how it was on 63-69's and I don't think they changed it for 72 someone else might chime in here to correct me if I'm wrong. But from your discription that is typical matinence on a car the outers wear faster than the inners and need replacing sooner.
        As a side not the castle cut out on original 5/8" nuts are square on the bottom service replacemnts are round.
        Rich
        • Steve L.
          • June 30, 2001
          • 763
          I'll check the bottom of the nut cut-outs tonight to see if they are square or round.
          Steve L
          73 coupe since new
          Ottawa, Canada
          • Steve L.
            • June 30, 2001
            • 763
            Alan,
            I've checked the bottom of the slots on the castle nuts - they are all square cut.
            BTW, the 5/8inch nuts are located at the steering arm, not the relay rod side.
            In any case, after cleaning, I'm putting everything back the way I found it and investigate this further after I get the body back on.
            Steve L
            73 coupe since new
            Ottawa, Canada
