do they take points away if you have your clutch pedal in the short throw position as they do for the 4speed short throw.
judging clutch pedal question 63-67
Re: judging clutch pedal question 63-67
Bill -- I realize that the '65 judging guide does not specifically mention high or low pedal adjustment, but to be consistent with the paragraph below, IMHO, there should be a flight deduct for non-TFP. Same for the shifter rods being inserted in the lower holes on the trans sidecover [1-2, 3-4] levers for a short throw (ie. not TFP). If the judge can read the maincase and sidecover casting numbers, he/she can see where the rods insert.
The above items should be treated the same as for the quick steering. '65 TIM&JG says "Steering Knuckle .... non-PS cars use hole furthest from the spindle on the tie-rod ends". So there is (should be) a deduct [or at least a mention] of TFP for those manual steering cars with the N40-quick steer hole being used.- Top
