A Lesson learned on C3 Tilt-Telescope Column - NCRS Discussion Boards
  • Roger C.
    • March 1, 1998
    • 83
    So members may not make the same mistake, should you disassemble a TT Steering column for a C3, be sure and mark the Long Shaft and Short Ball Shaft during disassemble. They can be mistakenly reassembled 180 degrees off. That causes the turns signal cancelling cam to be out of phase 180 degrees. This was a lesson learned the hard way, but practice makes perfect.
  • Graeme B.
    • October 23, 2007
    • 213
    Re: A Lesson learned on C3 Tilt-Telescope Column
    Thanks Roger, I don't need anymore "practice".
    • Jim S.
      • August 31, 2001
      • 730
      BTW, I have a complete set of instructions on rebuilding and repairing the C3 T&T steering column. The possible misassembly of the steering shaft at the plastic tilt joint is reviewed as well. The Saginaw locking steering column is unforgiving if the steering shaft is 180 degrees out of phase. (The turn signal cancelling requires more than 180 degree turn of the steering wheel.)
      Here is a direct link to T&T Disassembly & Repair Paper #3 in PDF format that reviews the steering shaft assembly.
      The rest of the papers can be found at:
      www.corvettefaq.com
      Click on Steering Papers
      Click on Jim Shea's Steering Papers
      Click on Corvette Steering Papers
      Scroll down to the T&T Steering Column Section
      Jim
