I am trying to remove the differential front bracket on a 1965 because the early design rear has left the front holes egged. The car has a bad clunk like you would expect and the rubber cushions are also in very bad condition and need to be replaced. Are these cushions # 3795333 and 3788637 still available from GM??
The rear bracket through bolt is frozen in the carrier and I can't budge it. I tried heat, six point socket etc. Short of taking the rear out to remove this stuck bolt I would like to know if anyone has any better suggestions. I have not done any damage to the bolt head and I have been careful not to break the bolt.
Today I mixed some acetone and ATF and sprayed in hopes some would get inside and free the bolt from the rear. Brother cringes about removing rear fearing opening pandoras box.
All suggestions are appreciated..
