I am having my machine shop resurface the flywheel out of my brother's '62. It has some cracks that go over the edge of the machined surface. The machine shop has told me as long as it will not be seeing "heavy hard service" such as drag racing, it should be fine to use. Does anyone disagree with this? Thanks!
Would you trust this flywheel?
Re: Would you trust this flywheel?
It MAY be fine. But why gamble for a modest amount to get a new one? Imagine the cost to repair/replace if it does crack or break down the road. Plus the secondary damage it will cause. Is that worth gambling on? My vote would be to replace and be done with it.- Top
David
Who is going to know whether you have the original flywheel or not? I understand that having an all original car is nice but let's be practicle about it. Would you drive on tires that old? It's not Judged, no one can see it and won't you feel better not worrying about it?
Terry- Top
Short, non-connected cracks in flywheels and brake rotors are okay as long as they don't reach the edge. IMO this flywheel is potentially unshafe.
You should be able to buy a reasonable facsimile, and it's not something that can be seen. Unless you have a 4:11 gear, buy an OE replacement, which should weight about 30 lbs, not the 18 pound "L-88" flywheel.
Duke- Top
My 2 cent: I would replace it as insurance and peace of mind knowing I would not have issues down the road. I asked a similar ques with original motor mounts and went with new ones in the end-I don't need the risk, you know?
If you believe it's original to the car, keep it and offer it with the car if you ever sell.
Pat
68 427 / 400
88- Top
All------
I agree; I would not want to use this flywheel. However, there is a problem here. This flywheel should be a GM casting #3729004. I do not think a flywheel of this configuration is currently manufactured or available in reproduction or the aftermarket. It's long-since GM-discontinued.In Appreciation of John Hinckley- Top
Hey if you have a good health policy, run that flywheel. A good surgeon can always sew your foot back on.
Even at lower rpms that flywheel can cause quite a mess when it cuts loose.
- Top
