I'm currently in the process of putting my interior back together again
. Although I've owned my '71 base engine auto coupe for nearly 32 years, I've never had the interior completely apart and, when I took it apart, it was readily apparent that whoever owned the car in its first 7.5 years really messed things up with the use of completely wrong or incorrect screws to put it back together (plus all of the panels were painted gloss black, the glove box compartment was missing, and so on)
. I've just about got everything to where it is supposed to go except for a couple of areas:
Windshield garnish moldings - top piece (page 31 70-72 TIM&JG) - part number 3922299 in the assembly manual UPC 1 ASM sheet F7 item #6 - what is the finish on this screw and is it supposed to have a washer (captured or non-captured)? There is one screw that goes in horizontally on each side, just inboard of where the outer screw for the sun visor attaches on each side. I don't see a washer shown in the assembly manual but my top piece appears as if a washer was installed on each side. If someone has the exact size of this screw (and washer, if appropriate), that would be great!
Rear quarter trim panels - top and bottom visible screws (page 26 70-72 TIM&JG) - assembly manual UPC 1 ASM sheet F18 - the TIM&JG talks about some coupe panels being drilled for a bottom screw and mine is one of them. Is the bottom screw supposed to have the P/N 140270 washer as well? I don't see it shown in the assembly manual for the bottom part of the panel but my panels appear as if there was a washer installed at one time.
Back window trim (panel below removable rear window, mentioned on page 30 of the 70-72 TIM&JG) - the two attaching screws - assembly manual UPC 1 ASM sheet F18 item #4 - part number 3922299 - I don't have any idea on the dimensions of this screw or its finish. If someone could help me out on this, that would be great!
Except for a few diehard car buddies of mine, most people around think I'm crazy to go to such lengths in trying to make the interior the way it is supposed to be. But, it's in my blood and I cannot let it go. Besides, I don't think my wife or either of my two sons are going to do it, so it's up to me!
Thanks to everyone.
Best Regards,
Randy Corrigan
Olympia WA
. I've just about got everything to where it is supposed to go except for a couple of areas:Windshield garnish moldings - top piece (page 31 70-72 TIM&JG) - part number 3922299 in the assembly manual UPC 1 ASM sheet F7 item #6 - what is the finish on this screw and is it supposed to have a washer (captured or non-captured)? There is one screw that goes in horizontally on each side, just inboard of where the outer screw for the sun visor attaches on each side. I don't see a washer shown in the assembly manual but my top piece appears as if a washer was installed on each side. If someone has the exact size of this screw (and washer, if appropriate), that would be great!
Thanks to everyone.
Best Regards,
Randy Corrigan
Olympia WA
