while driving car today and after getting fuel my car a 1967 427-390hp stalled. My car started right up when the key was turned...Any ideas?
car stalls while going and restarts easily
Re: car stalls while going and restarts easily
[quote=Joe Opatovsky (43135);488466
while driving car today and after refueling my car stalled.My car is a 1967 427-390hp.It has never done this before and woundering what it could be. Last year I did some minor work to her and it ran fine.- Top
Joe;
Wayne's question was whether the engine stalled as if the engine was'nt getting any fuel, or if there was a loss of electrical power to the engine harness. The front harness connector at the fuse box, on the engine side of the firewall (under the master cylinder) can become loose, causing this symptom. When this happens, you can open your door and see if you have courtesy lights at the kick panel. If not wiggle the connector and you should get the power back. You may need to repair the connection to get it to stay, or "adjust" the pins so they will make contact.
If this isn't it it's most likely fuel related, possibly a fuel delivery problem.
Paul- Top
Or maybe the ballast resistor is intermittent and restarts easily because it gets bypassed when you crank the starter?
I'd check ballast resistor & connections.
Rich- Top
Did it just stall once and restart with no further issues ?? If it was a one time deal, it is probably nothing to worry about. Now, if it continues to die and restart, we need to dig deeper.Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
- Top
