lean mixture on hard run - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1354
    Took my '67 L79 out and did a few full throttle short time period runs up through 2nd and 3rd. Close to 5 grand power dropped off and was one or 2 "pops. Went back home and discovered an extremely low secondary float level. I corrected this ( have a Holley 3367 rather than 3810) went back out and it pulled strong, no smoke (wasn't any smoke before, either) or miss. Any chance I did burn a piston, etc., or is all probably well?
  • Bill I.
    • January 29, 2008
    • 554
    Re: lean mixture on hard run
    Bill, you're fine. Don't sweat it for that short period of time. Bill
    • William F.
      • June 9, 2009
      • 1354
      How can I tell for sure ,short of borscope, teardown,etc. Is a good steady vacuum a good indicator that all is well?
      • Timothy B.
        • April 30, 1983
        • 5177
        William,
        The L-79 should idle at approx 750 RPM/14" vacuum. Strong vacuum is always a good indicator of internal engine condition. I think you are fine..
        I think a lean condition would be reflected in the spark plug and if detonation from lean the plug will not be clean. Is the fuel pump pressure OK and have you leaned the primary jets without enlarging the PVCR .
        The sq in" of the jet area needs to be maintained for WOT conditions.
