Sorry to resurrect this topic again, but recently there was a question posed about the quality of front suspension rebuild components available from CC, Paragon, etc, vs NOS. I missed the response and have had no luck in the archives. I've priced king pins, upper and lower inner and outer pivots from CC, Paragon, Doc Rebuild and NAPA and find a fairly wide range in prices.
I'd think these pieces would likely be single sourced due to the low demand, so the question is, does anyone know if there is any difference in quality or would it be resonably safe to buy based on price alone?
Thanks for any insights.
, and I had to use spares from my parts stash as the originals were rusted. The lock studs were over sized also, the flat on the stud not ground enough, and would not fit in the knuckle fully and not used. I re-used the original lock studs, and went to use the new lock washer and nut, and turned out the studs in the kit are metric threads.
