Coil Bracket - Correct? - NCRS Discussion Boards
  • Larry T.
    • May 15, 2007
    • 404
    Does this coil bracket look right for a 66 big block car? Is the hole above the screw head correct?
    Thanks.
  • Larry T.
    • May 15, 2007
    • 404
    Re: Coil Bracket - Correct?
    Does anyone have a picture of a known original that they could share? Thanks.
    • Ronald L.
      • October 18, 2009
      • 3248
      Larry I pulled mine out this last weekend just to see if it was the original 232 coil as I expected and it was In the fantastic photo, you can see one hole, but I don't see the second one right by the screw head.
      • Larry T.
        • May 15, 2007
        • 404
        Ronald, Is yours for a big block? Does it have TI? 232 is not a number I am familiar with for a TI system. Also, is your bracket straight or angled?
        • Keith B.
          • March 7, 2008
          • 928
          looks like the one on my 66 396 Chevelle. but I cant say that its original to the car. I know its a real GM bracket
          • Ronald L.
            • October 18, 2009
            • 3248
            Larry, 427 base 390 no ti and yes it has an angle to it. Not sure on the condenser as the AIM calls for a 1947452 and this condenser is a 1959455.
