Well I finally got around to installing the exhaust system from a well know recommended vendor.
The short piece of pipe on the passenger side that the tip slides over is 5" on the passenger side and 4" on the driver's side. What is the correct length? Wish I had noticed before mounting it in place.
A 1/2" or so would be okay. Should I try cutting the longer side? The problem is that the tip starts to hit the bent portion of the pipe and It really will be difficult to get good alignment on the tip.
Thoughts? I had the system sitting for almost two years before installing.
Bill
Bill
