Very Interesting "Bolt Science" - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    Here is what I found while researching the phenomenon of loosening header flange bolts.
    Whiz-Lock is a registered trademark of the MacLean-Fogg Co
  • Bill M.
    • April 1, 1977
    • 1386
    Re: Very Interesting "Bolt Science"
    Originally posted by Joe Ciaravino (32899)
    BE SURE TO CLICK ON THE VIDEO LINK AT THE BOTTOM OF THE PAPER.
    Did I see no. of cycles = Hz. ?!
    • Michael W.
      • April 1, 1997
      • 4290
      Yes. In the test the bolt with the plain washer came loose in 300 cycles, with a spilt washer it came loose in 500. No surprise there. I learned long ago that washers, french locks, lock wire etc. does not stop a fastener from coming loose, it simply prevents it from falling apart completely. Sometimes.
      • Dick W.
        • 10483
        Properly installed, safety wire works every time
        Dick Whittington
        • Joe C.
          • August 31, 1999
          • 4598
          Yeah, I didn't understand that either. AFAIK, Hz = cycles/sec, not cycles.
          Here's where I saw it first:
          • Robert S.
            • May 31, 1988
            • 81
            Seems to leave two choices for exhaust manifolds, french locks or Stage 8 bolts. So far, french locks have worked for me.
            Bob
            • Joe R.
              • May 31, 2006
              • 1822
              Bill and Joe,
              Technically, you are both correct (Hertz = cycles per second). But sometimes cycles is used informally as shorthand for cycles / second. E.G. 60 cycle power.
              Joe
                • 43193
                Joe------
                I'm glad to see that they agree with my long-held opinion that split lockwashers are useless. If they had come to any other conclusion I would have questioned their credibility.
                • Michael G.
                  • November 12, 2008
                  • 2155
                  I'd be careful about extrapolating the results of Junkers tests to apply to all threaded joints. I think these folks have over-simplified it to the nth degree.
                  I do like their initials, though....
                  • Bill M.
                    • April 1, 1977
                    • 1386
                    Originally posted by Joe Raine (45823)
                    Bill and Joe,
                    Joe
                    Joe:
                    I think the abscissa is cycles, not cycles/sec...
                    Bill
                    • Joe R.
                      • May 31, 2006
                      • 1822
                      Joe:
                      Bill
                      Bill,
                      You lost me there. Did you mean numerator or denominator, or what? Cycles is unit less. Cycles per second means how many 360 degree cycles of a waveform (sine wave, square wave, etc) are there in one second.
                      Joe
                      • Charles F.
                        • April 30, 2006
                        • 99
                        Didn't know what "abcissa" was. Per Wikipedia:
                        The first of the two terms by which a point is referred to, in a system of fixed rectilinear coordinate (Cartesian coordinate) axes. The abscissa is also known as the "x" coordinate of a point, shown on the horizontal line, with the ordinate, also known as the "y" coordinate, shown on the vertical line.
                        The point (3,2) has 3 as its abscissa and 2 as its ordinate. Chuck
                        • Bill M.
                          • April 1, 1977
                          • 1386
                          Bill,
                          Joe
                          (Sorry, Joe. Too many math classes.)
                          I think the x-axis is cycles, not cycles/sec.
                          Bill
                          • Joe C.
                            • August 31, 1999
                            • 4598
                            Well done!
                            Now, name the three axes in solid geometry.
                            • Richard J.
                              • February 18, 2010
                              • 46
                              I've had a problem keeping the header bolts tight on my exhaust manifold. What to you call the washers shown at the 9 o'clock position on the blue background pic at the bottom of the page? (interlocking washers split the long way) Header company sold me a handful of those and I have them on the car now. Was curious as to the name of them.
                              Unfortunately, french clips wont work with my headers.
