How many if any C 2'S came out with no vin stamped on the engine pad? Just curious I saw one advertised and I have never seen one with no vin that I can remember. Tom
Vin #'s ?
Re: Vin #'s ?
Unless I've missed something. I'm going to say none left the factory in a car unstamped. Never know though. John might be able to tell us stories........................................... ..........Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
Re: Vin #'s ?
Correct me if I'm wrong, a warranty or over the counter block should have a CE# on it, yes? As far as the engine's build date/engine code goes that could have been added by anyone. My CE block's casting date is less than 1 year newer than my car's build date and the dealer (I'm assuming that the dealer did this under warranty) stamped the engine's origional build date/engine code was stamped onto the deck. It is sloppily done and nearly half is under the head.- Top
Re: Vin #'s ?
The CE stamping didn't start until 1969, so I guess there are a couple of reasons why an engine wouldn't have the serial numbers. I think Flint and Tonawanda would have had control over the CE stamping.
1. Over the counter long block
2. Warranty replacement engine before 1969
3. ?- Top
Re: Vin #'s ?
Replacement Service short-blocks weren't pad-stamped, as their application suffix wasn't known. "CE" 5/50 replacement short-blocks only had the "CE" number stamping. Complete replacement engines were available through Service while they were still in production, and they were stamped with the engine plant machine code stamp, but had no VIN derivative stamp; that's probably what this one is.- Top
Re: Vin #'s ?
Does that mean there were no CE long blocks produced?- Top
Re: Vin #'s ?
When my '69 Z/28 engine went out in a blaze of glory in May, 1970, one of the heads went with it; it has the "CE" short-block with an original 186 head on one side, and a '70-dated 186 head on the other side that they had to order. All the other bolt-on parts are original.- Top
Re: Vin #'s ?
That's correct - "CE"'s were supplied either as short-blocks or as "fitted" blocks (pistons only). All other bolt-on parts were to be transferred from the failed engine, or ordered separately.
On the short blocks, there must have been different part numbers for the appropriate piston/cam configuration, even though there was no suffix code. My 67 Nova has a 69 cast CE shortblock in the L-79 configuration with high compression pistons, 151 cam and 8 inch balancer /timing cover. The original engine was the 275 hp L-30 and I suspect the engine was replaced under warranty and the owner upgraded to the L-79 replacement CE shortblock....not sure if it would have included the 8 inch balancer or not, but it did have the proper timing cover and drilled crank.- Top
Re: Vin #'s ?
Is there a partial VIN stamped on the driver's side of the block near the oil filter? My 1970 Camaro SS350 (from Tonowanda) has the partial VIN stamped near the oil filter. It is not easy to read because the area is not machined. My 1970 Camaro assembly manual (UPC 6, sheet A2) shows two locations for the partial VIN to be stamped on the block. I can not find a similar page in my 1966 Corvette assembly manual for this partial VIN stamping. The 1968 Corvette assembly manual (UPC 6, sheet A1) only shows one location for the partial VIN stamping.- Top
Re: Vin #'s ?
That's correct - the "CE" short blocks were ordered by part number from a chart based on the specific application so the innards would be correct for that application. Unfortunately, that part number only appeared on the shipping paperwork and on the crate it came in, not anywhere on the engine.- Top
