C1 Crossover exhaust - NCRS Discussion Boards
  • Leo M.
    • May 31, 1995
    • 35
    I recently installed an exhaust with the crossover on my 62. The crossover pipe is not horizonatlly level. I cannot find any dimension details for the crossover cutout on the exhaust pipes. Since I need to redo this I'd like to have it correct. Anyone know what the dimension should be?
  • Terry D.
    • May 31, 1987
    • 2690
    Re: C1 Crossover exhaust
    Leo
    Which side is up? Which side down? Where did you get the exhaust pipes? Is the heat riser installed?
    • Leo M.
      • May 31, 1995
      • 35
      The right (passenger side) is down. The 1" spacer for FI cars in lieu of the heat riser is in place. The exhaust was provided by Paragon Reproductions. The distance between the top of the pipe and the crossover cutout on the right side is 5" and the same distance on the right side is 5 3/4, which not only does not allow for the spacer/heat riser, but is longer to start with. I contacted Paragon and they sent replacement pipes. The distance from the top of the new pipe to the cutouts is 5 1/4 on the left and 5 5/8 on the right which doesnt solve the problem. I can cut the right pipe to make the crossover horizontally level with the spacer installed, but if there was a factory specified diminesion I would like to make it correct.
