1979 L82 exhaust oil - NCRS Discussion Boards
  • Ron S.
    • May 10, 2010
    • 24
    I have oil coming out of the drivers side exhaust. The compression is ok and the plugs are clean. The original 350 engine was rebuilt in 2006 and the car has been lightly driven since 2500 miles. Any suggestions what is causing this?
    Thanks Ron
    • 15573
    Re: 1979 L82 exhaust oil
    Thanks Ron
    How much oil ar eyou using between changes?
    Maybe the rings have not yet seated.
      • 11608
      Silly question.... you're sure it's oil?
      It's not unusual for "black water" to come out of the exhaust of little used cars. It drives my friend's wife nuts because his Austin-Healey spits it on the floor of the garage and makes it dirty. I've seen other cars do the same thing, though.
      It'd take a heck of a lot of force to push oil all the way through the cat converter and exhaust system and then come out the end...
        Thanks Ron
        Ron-----
        If you've actually got oil coming out the exhaust, the car would be smoking like a WWII destroyer setting down a smoke screen and your oil consumption would be so high you'd be adding oil every time you drove the car.
        • Tom H.
          • December 1, 1993
          • 3440
          My thoughts exactly ! Double check to be sure it's not just moisture. If it is indeed oil, we might have to dig deeper.
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • Pat M.
            • April 1, 2006
            • 1575
            I get some of this with my 70 when I first start it. Doesn't drive me nuts though.
            • Ron S.
              • May 10, 2010
              • 24
              Guys, one other thing my friend says the exhaust stinks when you follow me. Once before it stunk real bad, ate up the oil and smoked real bad out both sides and that was a pcv valve problem. This time not real noticible smoke and not a lot of oil being used. just black and wet on the one side exhaust tip and sticks. Any more thoughts Thanks Ron
              • Tom H.
                • December 1, 1993
                • 3440
                I'd say she's running rich and you have moisture in the exhaust. The result is the black sooty moisture you see coming from the muffler. Of course I haven't seen your car, but from the info we have so far, I'd say that's the case.
                Have you done any recent work to the car that may have caused this condition you are noticing ??
                Have you had the car long. Has it always done this or did it just begin ??
                Tom Hendricks
                  • 6940
                  Ron, I think Tom has you on the right track, soundslike a fuel related problem, just to add some advice, take a look at the Automatic choke sometimes when there not operating properly they will cause the engine to run rich, and give you that smell out the tail pipes,
                  The electric choke is run on 12 volts, and has a wire on it that tends to lose its connection from a rusted terminal. The choke butterfly should be wide open after a few minutes of running.the warmer the engine the shorter time it stays open. and the colder it is the longer.
                  If all checks out with the choke, check to see if the charcoal canister is drawing un metered fuel into the carburator viva through the vaccum hose at the base of carburator.
                  • Ron S.
                    • May 10, 2010
                    • 24
                    Thanks guys I think were on the right track, I recently put duel carbs on it. The engine has a moderate cam and headers. I will look at the fuel issue tommorrow. Ron
                      • 11608
                      $10 says it's running way too rich.
                      What carb, cam and headers? Did you change anything else?
                      • Ron S.
                        • May 10, 2010
                        • 24
                        Patrick, The cam is engine pro stage 3 duration .050 int exh 224 adv duraton 290 290 valve lift 465 465 lobe 107 117 power range 2000 5000. carbs are 500 cfm Edelbrock headers are hooker pistons flat top. Thanks Ron
                          • 11608
                          Elgin "pro stage3" camshaft? do you have a part number?
                          Edelbrock carbs, I assume?
                          What brand and model of pistons?
                          Auto trans or 4 speed?
                          • Michael W.
                            • April 1, 1997
                            • 4290
                            Two 500 cfm carbs on a 350? I think I see a problem right there.
                            • Tom H.
                              • December 1, 1993
                              • 3440
                              A problem for drivability............. or judging !!! ??
                              Tom Hendricks
