Here's my situation: I'm having an engine built for my 1960 Fuelie. The engine will be correct in appearance but it will have a 327 Stroker kit installed with roller tip rockers and solid lifters. Jack Podell, who sold me the fuel injection unit emphasizes that it is critical to have the correct cam in the engine. He advocates a 097 Duntov cam however I don't think that he knows that it will be a Stroker engine. The engine builder originally wanted to put a .30 - .30 cam in the engine but I was told that it would have too much of a loping idle and it may not pull enough manifold vacuum. He now suggests a E900P cam for this particular engine configuration although I'm told that this is just a 30-30 cam.
I've searched the archives and found comments from Duke Williams and John DeGregory who both had good advice (See 63 327 fulie motor; September 25, 2006) Duke suggested a LT-1 cam and John the Speed Pro CS 113R but I thought I'd ask the group if they have any other thoughts or recommendations. Thanks.
Hard to believe that they can work their way thru the oil pump screen. With that said, I have not heard of a failure of Crane or Competition roller rockers in quite a few years.
