ignition shield capcitor - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Where does it connect on the inside if at all?? What size wire?? Thanks as always!!
  • Roy B.
    • February 1, 1975
    • 7044
    Re: ignition shield capcitor
    The shielding uses a different Capacitor design then the voltage regulator , bottom pic. VR and top pic. shielding and the inside wire goes to the coil , same size wire as the out side wire
    • Guy M.
      • November 1, 1993
      • 499
      Thanks Roy! What a resourse. Mine has the VR there. Does it make a functional difference which one is used? Also, do these things ever wear out? I'm assuming the wire connects to the negitve side of the coil? Its amazing we cant find this info easily. I do appreciate your knowledge!!
      • Roy B.
        • February 1, 1975
        • 7044
        Originally posted by Guy McMann (23539)
        Thanks Roy! What a resourse. Mine has the VR there. Does it make a functional difference which one is used? Also, do these things ever wear out? I'm assuming the wire connects to the negitve side of the coil?= NO Its amazing we cant find this info easily. I do appreciate your knowledge!!
        It dont make a difference which one you use , just the design of it. Yes they act some what like a fuse and can short out , the wire inside is thin. No the X
