My 56 motor was rebuilt using a new rope seal. It leaked a small amount during break in and has not been run since. While I have the pan off now, I was planning to replace the rope seal with the Paragon 56 seal. After removing the rear main cap I discovered the crank is pitted in the seal area
. I'm afraid to install the new neoprene seal for fear it will leak more than the rope. I'm thinking that the rope might be better since it has more surface area. HELP!
Has anyone installed a double lip seal designed for later blocks in a 56 by modifying the seal to fit the v-shaped goove?
Thanks for any responses.
Tom
. I'm afraid to install the new neoprene seal for fear it will leak more than the rope. I'm thinking that the rope might be better since it has more surface area. HELP!Has anyone installed a double lip seal designed for later blocks in a 56 by modifying the seal to fit the v-shaped goove?
Tom
