Hi All, Happy Memorial Day,
I need to know how the hood latches on a '54 are secured.
Now before you think "that's a dumb question" let me explain. I want to remove the firewall-mounted latches from my '54 and I can clearly see the bolt heads on the engine side of the firewall. What I need to know is what's on the passenger compartment side of the firewall. Are there nuts and washers? Is there one large nut plate?
Reason I ask.... The firewall insulation blocks my view and prevents convenient access, as does the heater. I have arthritis in my hands and I don't want to make this a larger project than absolutely necessary.
If there is a captive nut plate, then I can easily remove the latches. But if there are individual nuts and washers, I'm not so sure I'm motivated to also pull the heater and firewall mat.
Thanks in advance,
Jim
Thanks in advance,
Jim
