I'm enjoying the Memorial Day weekend by doing some needed maintenance on the old 66. I've finished "tuning" it up and it's running well. As someone who doesn't have much experience tuning cars, each time I do it is a chance to learn some more. This year's tune up had me thinking about dwell and timing.
To start, here's the basics - My car has it's original 327/300hp. It's a K19 car but the AIR has been disabled - belt removed and AIR tubes removed with plugs put into the exhaust manifold. The engine has over 40,000 miles on a rebuild that the original owner had done. He told me that it had a "mild" cam in it - but it's still a hydraulic cam, just with a bit of a rumble to it.
I have a fairly good understanding of timing but have always just set the dwell to 30 and went on to setting the timing. This tuneup had me thinking about this a bit more. Just what exactly is "dwell". I'm not sure I understand exactly what I'm setting when I do this.
The reason I am pondering is that the points I bought were so out of whack the car would not start when they were first installed. I removed them and compared them to the old ones I took out and saw that the allen screw was noticably further in on the old ones than the new ones. I screwed the allen screw in further on the new points to get somewhat close to the old ones and then reinstalled them. The car fired right up and actually idled really well. I checked the dwell and it was around 20 vs the spec of 28 to 32. As I adjusted the allen screw to move to the spec, the engine lost rpm. I checked the timing and it was moving from 18 degrees advance to about 5 degrees advance at 30. I decided to set the dwell at 28 and then adjusted the timing to spec at 6 degrees (idling at about 500 rpm). I then set the idle back up to 700 to improve it's drivability - I'm guessing that's because of the cam.
With all of that as background it made me think about dwell. What exactly is it? Is dwell the length of time that spark is transmitted? Why as the dwell is increased does the timing retard? And finally, at the end of the day, is dwell something to just set and forget?
Thanks in advance for helping advance (pun intended) my understanding.
Cheers
Mike
Cheers
Mike
