I have a '64 FI TI roadster. Now that the FI problems are sorted out
, I have electrical problems. I am on my third coil in as many months. The first (well, second since original) was purchased from Jack Podell as the "Correct" coil for my car. It went out and was very very hot to the touch
. The second was an old coil from Jerry Bramlett that had the correct numbers and all but best of all... it worked
It went out last week
I have replaced the original TI amp with one from Dave Fiedler. He says if I blew the brain I would be the first in 16 years; so he has confidence in his product and I believe in him.
I replaced the harness from the TI unit (amp) to the coil and dist and I replaced the FI solenoid bypass wire. Both were from LL.
By the way NAPA has a direct replacement in their computer for the 1115207 coil which does NOT work!
Question is: what could be taking out my coil(s)?? Is it just fate? Stray electrons? The car has never been through San Francisco
What do I check and how do I check it?
.It went out last week
.I have replaced the original TI amp with one from Dave Fiedler. He says if I blew the brain I would be the first in 16 years; so he has confidence in his product and I believe in him.
.What do I check and how do I check it?
