I would like to rebuild this myself. All kits I have looked at say for "stainless sleeved only" Do I have to send it out to be sleeved ? I want it repaired not restored. Thanks for your help. Jeff
Leaking Front Caliper
Re: Leaking Front Caliper
Have your calipers ever been replaced or sleeved? While not impossible, the odds of a 41 year old car still having its original calipers are small, very small. Unless you are the original owner, I would first confirm the casting numbers of the units (post them here) to see if they are correct for your car. Also tell us what color they are painted.
If by chance they are original, then they are probably pitted inside and will have to be sleeved. Replacing the seals will be nothing but a very short term stop-gap measure.
Many places (Vette Brakes, etc) will restore yours and send them back to you, which may be worth it if in fact they are original. I've done this a couple of times. If they are later castings (which is easily possible if a prior owner replaced them) then you can buy brand new correctly numbered already-sleeved units from Lonestar. I've also done this for a car I just finished working on.
Let us know more about your calipers and we can help from there.
The numbers won't help one way or the other. Any caliper can be modified to accept an S/S sleeve. It will need to be removed and disassembled for positive verification.- Top
Also, if they're painted silver then it's a no-brainer.
I'm simply saying that the casting number will not confirm/deny the existence of SS sleeves. Yes, the numbers might prove to be correct for that particular car but that doesn't help get the caliper fixed.- Top
True. My point is that if they're the wrong ones he has no need to worry about their "rightness" and whether they can be rebuilt or not. Even if they're SS sleeved, if they're leaking and the wrong casting numbers I'd get rid of them.Vice-Chairman (West), Michigan Chapter NCRS
Nothing special about parts used to rebuild my stainless steel sleeved calipers.
Since I had to remove the calipers, I also removed the brake disc and cleaned the wheel bearings, packed them with new grease, and installed new grease seals.- Top
Thanks again for all the responces. All four calipers have a coating of rust but I can see parts of black.
The right front leaking caliper has a number of 5452270
Left Front 5473796
Right Rear 5473806
Left Rear 5478806
Any help in identifying these would be a great help. Jeff68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
2014 Arctic White Z51 Vert. (Wifes)- Top
In looking up some numbers on Google,it seems my only original one is the leaker. These are only the inner numbers ,but I believe the right front inner is the only original so far. I'll be taking off all wheels this weekend to remove and correct. Thank you,Jeff68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
Let us know if it has been sleeved or not.
Yes, of the 4 numbers you posted only the 5452270 could be original to the car. That's not to say that it actually is original to the car. It might just be by "accident" that it was supplied as part of a rebuilt caliper assembly. You'll know more when you get the numbers from the outside calipers. Sometimes, you can even see these numbers through the slots in the wheels.
The 547-series calipers are, by far, the most common ones out there in core stocks. That's because they were used in PRODUCTION and SERVICE for a much longer period of time than any others.In Appreciation of John Hinckley- Top
Well I took the leaker off. The outside has a number of 5452273 . The manual states there is a date code stamped on the bottom. A saw a stamping of 12 / 97 , including the slash. Any input ? thank You, Jeff68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
5452273 is a caliper half casting number originally used for your car. Whether this is actually the original casting installed on your car is another matter. It's pretty much moot, though.
The stamped date code is likely when the caliper was sleeved and rebuilt. There were usually no date codes stamped on original calipers and certainly none with a date code of 12/97. You will likely find that this caliper has been sleeved. So, you will likely only need new pistons and seals to repair it.In Appreciation of John Hinckley- Top
