C-2 Inner Fender sound deadener, Help! - NCRS Discussion Boards
  • George P.
    • August 31, 1988
    • 17
    Originally an under-coating/sound deadener was sprayed in the fender wells, I believe to reduce the possibility of "star-bursts" in your paint. My inner fenders are clean now, my question is what would be the best undercoating to use for this application that would "best" protect against rock damage causing "A" surface paint damage? Any and all input will be appreciated.
    George Poynter
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1464
    Re: C-2 Inner Fender sound deadener, Help!
    Looks like no takers, George.
    Plenty of detail in the archives.
    HaND
    • Wayne W.
      • April 30, 1982
      • 3605
      The thickest stuff you can find. No spray can stuff is like original.
      Applied like this.
      • Stewart L.
        • March 1, 1980
        • 351
        Check with a body shop supply store, there are manufactures like SEM or Wurth have thick undercoat products that will match the factory texture. You would probably need to buy a special gun. I have also wondered how the spray on pick up bed liner material would work to protect the underside of the surround panel in the wheelhouse area. I have never tried it but the stuff is tough.
        • Ronald L.
          • October 18, 2009
          • 3248
          I have not tried it yet - but seems to fit the specs - Duplicolor makes a paintable undercoating # UC101, available at the local big box stores.
          • George P.
            • August 31, 1988
            • 17
            thanks, guys for the input.
            GP
