68 wiper bezel assembly - NCRS Discussion Boards
  • Ed P.
    • July 31, 2002
    • 270
    Ok i have the aim picture of the 68 with air center vent louver. i am confused as to how many parts are behind bezel. I have #4 that is two pices but I do not have #1 or are they the same. Its on page H301 Ed
    Re: 68 wiper bezel assembly
    Ed------
    I believe the outlet (#1) is part of or attached to the center duct. The deflector (#4) fits into the outlet. The plate ("bezel") (#6) then installs over the deflector.
    • Ed P.
      • July 31, 2002
      • 270
      Is #4 one piece or two pieces. Ed
      • Bryan M.
        • April 1, 1999
        • 386
        My old 68. The deflector is one piece.
        • George W.
          • May 31, 2000
          • 543
          # 4 is defiantly two (2) pieces.
          One piece is the housing, and the other is the deflector.
          Both pieces are chromed, and neither has a part number on them.
          The deflector has a "pin" on each side and is installed from the back side of the housing.
          This is a one way installation. The left side pin must be inserted first, then the right side pin drops into place.
          The right side pin is secured with a black hard rubber "grommet" that is convex on the pin side, and flat on the outer side.
          All other info concerning the ducting and installation discussed here is correct.
          As per usual, these '68 pieces are one year only.
          I see the deflectors/housings quite often, the ducting somewhat less often, and the wiper bezel almost never (don't remember ever seeing one on e bay).
