67 Washer Pump Help??????? - NCRS Discussion Boards
  • Ara G.
    • January 31, 2008
    • 1108
    Hi. I am in the process of going through my operations recheck and low and behold my squirters aren't squirting. I pulled the nipple cover off and replaced it with an original one. I noticed that the one on the car was leaking and looked new. I put the original one on, with a new three circle rubber gasket and still nothing, and a leak. I primed the system both times using a syringe, and using distilled water it goes through the squirters and onto the windshield. Also I hear the clicking of the pump as I attempt to engage the pump. The rebuild kit comes with a large o ring that can't go onto the unit as the pump itself already has a large rubber, inset boot that goes into the pump and looks impenetrable (not sure how water even gets through it). There is fluid in the reservoir and the tube is submerged in the fluid. Any help? Any thoughts? I am at wits end. As always, any help is super appreciated. ARA
  • Gerard F.
    • June 30, 2004
    • 3803
    Re: 67 Washer Pump Help???????
    Ara,
    Take a look at this thread and the third post down:
    https://www.forums.ncrs.org/showthre...llows&uid=4105
    If the bellows is going back and forth with the click, (and it should make a clicking sound), the problem is probably with the little rubber check valves in the replacement little square plastic valve frame.
    Some of the replacement check valves just don't seal.
    I wound up putting my original check valve frame back on and used a little Sly-Glide (or like vasiline) on the little check valves. Before a meet, I lubricate with a little Sly-Glide on the check valves, works every time.
    That is, if the bellows is going back and forth?
    In you have redone the motor and housing, it has to be reassembled in the right position or the cog doesn't fit in the slot. If you can see or feel the bellows going back and forth when you turn on the washer and it starts clicking, then you are OK.
    A good check of the check valve, is that you can blow though the suction tube, but you can't suck through the tube.
    Nice to meet you in Kissimmee in January. Sorry we didn't get a chance to have a few brews.
    Jerry Fuccillo
    • Kirk M.
      • June 30, 2006
      • 1036
      Here's what I found out.
      1. All I had to do was remove the distributor shielding and then I could get enough access to the washer motor housing to remove it from the wiper motor housing. It was definitedly cramped for hands and wrenches but it can be done. There are four screws to remove (roughly in the four corners) so that the entire housing can be detached from the wiper motor.
      2. The screw in the bottom left corner facing the firewall has a ground plug attached to it that will need to be unplugged. Make sure you don't drop the metal plug bar when you remove the screw. Interestingly, this ground is for the wiper motor. So, when it is disconnected the wiper motor will not work and you can't test the washer unit until you reconnect it.
      3. When doing steps 1 & 2 be sure you DON'T remove the two screws holding the washer motor to the plate that then attaches to the wiper motor. Those screws are mounted through the plate with locking washers and nuts. They are located more in the middle of the washer motor unit as you might expect (and yes I removed one them and almost the second before I realized my mistake). Once removed, the washers and nuts are free to disappear into the void of the engine compartment as you remove the plate, so be careful if you accidently do this.
      2. Detach the line in and two lines out from the driver's side of the washer motor unit.
      3. Detach the plastic double plug from the leads on the wiper motor.
      4. Now you can weazle the washer motor unit and plate out of the engine compartment, and sit down and begin work on the unit outside of the car.
      5. Take the nozzel plate (where the hoses attached) off by removing the four screws. This frees up the plastic piece with the three diaphragms for removal and reveals the rubber bellows. In my case, everything just needed a good cleaning, but if either of the parts are damaged (cracked belows etc.), you can replace them now. Don't lose the three ring seal around the diaphragms - it tends to easily fall out. I could not free up the bellows easily when I tried and since I didn't replace it, I'm not sure what the secret is there.
      6. Looking through the back of the mounting face reveals a four-pronged white plastic wheel on the washer motor. At one point on this wheel is a rectangular seat that needs to re-connect to a projection on the wiper gear. This requires a bit of fidgeting when remounting the unit, but after three or four trys, I could tell that the nipple on the wiper wheel had seated. And of course they don't easily line up.
      7. Here's what I figured out. The wiper motor runs that wheel continuously and you can hand-crank it counterclockwise to test the functionality of the unit. Movement of the four prong unit makes a metal piece slide back-and-forth over the washer bellows gear (white plastic with curved teeth). However, in the "neutral" position the metal bar can NOT engage the teeth until a larger but similar in style bar (shaped like an oblong "O") is moved out of the way.
      8. Now for the magic. Press the window washer button and a small wound magnet just above both metal pieces pulls the larger metal "O" up permitting the smaller metal "O" to now engage the teeth of the diaphgram wheel. The larger metal piece pops into a thin metal catch at the top when it flips up thereby keeping it in place and out of the way until the washer cycle finishes.
      9. Now the wiper motor is spinning the four pronged piece which in now engaging the bellows wheel causing the bellows to pop out (if the plastic nozzel plates have been removed). Continued movement of the wheel causes the bellows to pump in and out creating the suction necessary to move the washer fluid.
      10. As the wheel turns a given number of time a missing section of the outer edge slowly progresses around counterclockwise until the metal retainer for the larger "O" bar that the magnet caught is now permitted to move out of the way. A couple more turns and BOOM down comes the large metal "O" dis-engaging the smaller "O" from contacting the gear teeth and OFF goes the washer fluid.
      11. At this point, I cleaned and greased all the parts and determined that everything seemed to be working correctly. You can plug the washer motor back in while it's outside the car, just MAKE SURE and REATTACH THE WIPER GROUND. Now, hit the washer button and watch everything work. It's pretty cool. Also, there are a lot of wires just above the wiper motor, which at this point is running uncovered. S, BE CAREFUL that none of the wires are in the way before hitting the button.
      12. I next got a glass of water, filled up my mouth and blew water through both of the washer nozzel hoses to check and make sure the nozzels were clear and fluid could flow. I then primed fluid through the feeder hose from the revervoir and no washer fluid does not taste good.
      13. At this point I reattached the plastic pieces over the bellows. First, seat the three diaphragm piece over the bellows. Make sure the the single in diaphram is up and the lower two exit diaphrams are down. Now place the plastic nozzel unit over this piece while holding it in place. My diaphram unit had two small plastic nipples at the top making the orientation only fit one way. But simply put, the in line in the middle should line up with the single upper diaphragm and the two out lines with the lower two diaphragms. Now, hold the pieces in place and attach the four screws.
      13. At this point, the unit can be re-attached to the wiper motor housing MAKING SURE to RE-ENGAGE THAT NIPPLE TO THE PLASTIC RECESS ON THE WASHER GEAR. Just engage the two pieces off center from attaching the unit and then slide the unit to the left until the holes line up for re-attachment. That way you can feel the springiness (word?) of the four-pronged wheel when it's engaged. It takes a bit of handywork at this point to get the screws in place without letting the two pieces disengage. Make sure you have the screws handy before starting the re-attachment process.
      14. Tighten up the screws, reattach the hoses, and reattach the electrical plugs. There is a correct front to back orientation for the washer magnet double-plug as it only works one way. You can determine this while you're testing it as the magnet part of the action will not work in one orientation. AT THIS POINT, I REALIZED THERE REALLY IS NO SEPARATE WASHER MOTOR, SINCE THE WASHER BUTTON SIMPLY ACTIVATES THE MAGNET PERMITTING THE WIPER MOTOR WHICH HAS BEEN TURNING THE WASHER MOTOR THE ENTIRE TIME TO ENGAGE THE BELLOW'S GEAR. Go figure, I guess that saved GM a motor?
      15. Press the washer button and step back - ok, you might have to press it several times before water squirts freely, but when it does watch out because it can give you an eyeful if you're standing next to the vent window having just pushed the button - duh!
      16 Nozzels can be adjusted by just turning them in/out from the center of the windshield.
      Hope this thread helps someone down the road. Trust me, if I can do this, so can you. Good luck!
      • Ronald L.
        • October 18, 2009
        • 3248
        Kirk, Thank you for the detailed reply, yes it will help, this is one of the items on my to do list. Given that, with some of the repro parts not sealing, where are the good one from CC?
        thanks,
        • Kirk M.
          • June 30, 2006
          • 1036
          That is where I buy most of my parts so probably. Could have been LIC too. Good luck.
          Kirk
          • Ara G.
            • January 31, 2008
            • 1108
            Thanks Gerry, and to all who replied. I got the system working. I primed the lines by blowing on the hose coming out from the reservoir to make sure there were no clogs in the lines or squirters themselves. THen checked the pump to make sure it was working. I then removed the plastic housing holding the one inlet and 2 outlet hoses. Sure enough, the 3 small rubber nipples were dried and hard. This gave me a good opportunity to swap the whole plasctic housing out for an original one. I installed 3 new rubber nipples, the new concentric cirle gasket and resinstalled. No leaks thank goodness. Then primed the lines again with a good gulp of air and tested the system. It worked. Obviously I got lucky with the motor being in operational shape, as well as all other things working. Thanks again for all the help. Appreciated as always....Gerry, the brews are on me the next time we meet up.....ARA
            • Gerard F.
              • June 30, 2004
              • 3803
              Ara,
              Glad to see you got the problem resolved. Maybe I'll take you up on your offer at Concord next month.
              Jerry Fuccillo
              • Gerard F.
                • June 30, 2004
                • 3803
                Kirk,
                If you had some photos to go along with your procedure above, it would make a very nice Restorer story. You might want to get in touch with Vinnie Peters.
                Jerry Fuccillo
